Online: baldy1450, Hilly
Rocker build air filter and bars
  • bloodog
    bloodog
    New air filter eBay { Kuryakyn 9512 Velociraptor Air Cleaner... the price was from yanky land ... AU $189.36 Postage AU $33.00 }  The one on my bike sticks so far out I can not apply the break for hiting my knee on it and looks like shit.
    The new bars...are fat bob bars used from yanky land of eBay as well AU $149.60 PostageAU $71.61 took about 1 month to get here, the chrome on the air filter looks so awesome
    Starting with the air filter first, this Saterday, hopeing for a good run then the bars, the bar rises are 5in and the indcators may hit the tank, if so of they go fuck it
    Looking forward to showing the new look Sunday .... well  hopeing so I also have a 30 pack of VB so lets see O yer and I know i need a tune after the new air filter gos on.
    If you have any tips love to hear from you and yep I have the work shop manual and a tourqe wrench
    Thanks bloodog
  • punkin
    punkin
    Suggest fucking the blinkers off from that dodgy underhanging bar position. I bought some clamps and moved them onto the fork tubes. There is a spare plug for them in the wiring to go there under the tank. First thing i did as they look fucking terrible.
    Then i swapped the standard bars out for short apes and it improved the handling no end.
  • steelo
    steelo
    Got my indicators set up the same way on the deuce. Try mounting them below the bottom triple tree. That way should you ever decide to get a clip on windscreen, you'll have the space on the fork for the clamps. Still plenty of suspension travel. Plus, I think they look better a little lower. wink
  • punkin
    punkin
    Yes, Danny Grey seat was on it when i bought it. Check the fork leg diameter, there is a couple different ones.
  • bloodog
    bloodog
    Well it took some time and patience but well worth the effort
  • FXDF08
    FXDF08
    Bloodog, reckon those bars turned out a treat! You can get different size risers (chrome or black), quite reasonably priced. Looks like you don't need to though, as tank clearance is okay???
    Make sure you've got some appropriate air filtration in that air cleaner ...
  • steelo
    steelo
    Would that air cleaner be tougher on the knee than a standard filter cover BD? Otherwise looks great.
  • Sparra
    Sparra
    Hey there BD...When you cut the wires to take the blinkers of I assume you cut them up near the bars...How many wires were in each of them, 2 or 3??? Those bars sure make a difference...I'm on the fence with the air cleaner,it looks like it sits out a long way...
    Cheers...
  • 06 Softail
    06 Softail
    I'm not keen on the look of the air cleaner, as it sits away from the bike too much. Kuryakyn do other better ones than that model.
  • Sparra
    Sparra
    Thanks mate..I want to move my blinkers to the forks as well but my blinker plugs have 3 wires in them and I think the actual blinkers only have 2 so not sure about the third wire..
    Cheers...
  • punkin
    punkin
    Where are the blinkers did you leave them off?
  • punkin
    punkin
     Scotty at Uralla (or formerly of Uralla) frenched in my plate for me, but i moved the blinkers to tiny leds under the seat and then put LED strips down the swingarm for tail/stop and wired up a dimmer circuit from a clip on youtube.
  • bloodog
    bloodog
    Thanks Punkin
    Great photo of blinkers awesome back end on your rocker
    I'm thinking of moving every thing to side plate and getting a chrome
    skull with break lights for eyes to cover the holes on the guard
  • punkin
    punkin
    No worries, hope it gives some room for ideas is all.
    RIP the bright lights number plate.
  • Stevef
    Stevef
    Bloddog the bike is looking good. Tire wise after lots of research it appears the 250 is the way to go. It is actually wider than the 260 when put on a rocker rim. Something to do with the 260 being pushed out of shape on the rim.
  • Stevef
    Stevef
    Yeh BD apparently tge dunlop 250 fits best. I think its the same 250 used on the victory's. If you to a search for fxcwc or rocker with 250 rear tire you will find the threads on the US hd forums. Spell tyre withban I not y.
  • bloodog
    bloodog
    dunlop 250 it is then
  • punkin
    punkin
    No mate i figure the tyre is big enough and expensive enough as it is. Not like you can ride on the side of it anyway though. I have my tyres changed at the motorcycle shop where i buy them.
    Harvey Morris has been looking after the mechanicals on my bikes for more than 25 years since i moved up here and i trust him to do a good job. That's worth more than a couple bucks in my pocket and he's about 20-30% cheaper than the Harley Dealership here.
