Slippery seat !!??
  • Joeli22
    Joeli22
    Hey guys - strange one.
    After fitting my aftermarket new leather seat a few weeks ago- I find it really slippery riding in jeans.
    I want to keep the leather supple, conditioned and protected, but I have tried a couple of different leather cleaners and they all make the seat very slippery.
    Any suggestions??
    I know people who rough up their seats or use liquids (dish washing liquid?) to remove the wax/sheen, but that all, of course, doesn't do the seat any good. Only other good suggestions I know (off the top of my head) are to grip the tank with your knees, or sew anti-slip material (just a couple of strips) on the back of your jeans where arse meets seat.
    I've never found it too slippery myself (YMMV) and I find being able to move around on the seat adds to the stability when cornering. Crushing your nuts when slamming on the brakes might be an issue though <img data-cke-saved-src=
    Maybe try to wipe down the seat firmly with a clean rag/cloth after you've treated it, to hopefully get the best of both worlds, or as close as you can.
  • bobby bob
    bobby bob
    OK, I'll say it coz I know it's the only logical suggestion, arseless leather chaps to match the seat.
  • Joeli22
    Joeli22
    No worries where do you buy your arseless chaps from....i'll go to the same store !!cheeky
    Thanks for the responses guys...... hopefully it is just a case of the seat getting softer as i use it and as the conditioners etc work.  I like to move my weight around abit, but as you say if i have to slam on the brakes i think i would end up on the tank !
    cheers J
  • Joeli22
    Joeli22
    No amount of conditioner cream is going to solve that !!!!
    Try something like beeswax water sealant or dubbin on the seat to help unsmooth it. What does the seat manufacture recommend?
    What about bear arse? or beer arse
  • brucefxdl
    brucefxdl
    hahaha
