Online: Soapbox2627, Hilly
Tyre Puncture = New Tyre?
  • srd0060
    srd0060
    Good way to sell tyres..... shop around HD is way far from cheap.
  • John.R
    John.R
    Depends where the puncture is.
    I've run a lot of plugs (just the standard dog turd plugs, not the mushroom plugs from the inside), you only really need to worry if the puncture is in/close to the sidewall, or if its a big messy shape that won't plug cleanly.
    I personally consider them SAFE (others might not, I don't really care). I ride the absolute fuck out of my R1, wheelies, knee down, quick speeds and it never crosses my mind that the tyre has been plugged. 2 weeks after I fix it I've completely forget about it.
    Im not gonna give you advice, just my experiences ;)
    If you're stressed, you can always pull the wheel off and get a proper mushroom plug from the inside (pending location of puncture). Or just get a new tyre.
  • keith
    keith
    8k on the tyre is 50% or better, go for the new option IMO.
  • FatboyMac
    FatboyMac
    I had a puncture on the rear of my Fatboy, got it plugged as the tyre still had about 6,000 km more wear left in it & I'm Scottish! I checked the pressure every time I went for a ride & my thought was if the pressure had dropped a bit then it was time to replace the tyre. Ended up wearing the tyre out, but never felt at ease so think if it happened again I would just put a new tyre on, like PB said $300 + would be cheap compared to the worst case scenario.
  • Odin
    Odin
    I had a tubed front tyre go flat while rounding a bend. To this very day I have no idea on how I held the bike up. Go with the new tyre option. the $300+ option will be the best because the the road and gravel will not be your friend if you fall. I will never run tubes again
  • steelo
    steelo
    Fixed the rear tubeless tyre on my deuce using one of those emergency plug kits from SCA in order to get to a lunch with Winger. Lasted the rest of the life of the tyre, another 10k or so. I was checking the air pressure regularly.
    Riding this wave of success, I used a can of spray sealer on the tubed front tyre after a puncture to get from Clare to Adelaide and up to Mannum the next day for another lunch at which stage the tyre shit itself in a big way. Popped another can in to get to civilisation and the front end looked like a catherine wheel spraying liquid rubber all over me and the bike blush MIssus ended up meeting me with the trailer.
  • Damo222
    Damo222
    I'd Just plug it. I've personally never had an issue with puncture repairs even to the point of one tyre having 3 plugs in it. I've only ever used the licorice style cords pushed in from the outside, never used glue either. I use them on my cars as well.
  • Hound_Dog
    Hound_Dog
    Fixed a bunch with sticky string, bikes, 4x4's never a problem...but only on screw/nail type punctures away from sidewalls
  • Wimbo
    Wimbo
    I've had a few plugged tyres and never had a problem. I never did highway speeds on them though.
  • Vic
    Vic
    If it's anywhere near the side wall replace it, if it's closer to the middle and you can still get a lot of K's out of it, get a mushroom plug fitted from the inside.
    Have never heard of one failing and Ive had a few over the years .
    Have used the quick repair ones to get me home but wouldn't trust one for the life of the tyre, on a car yes, slightly different outcome on a car if it fails though.
    just fit a tube,
  • robots
    robots
    did you ride bike to shop and now has puncture?
