Online: tussuck, Merv
tacko on dyna
  • fxst
    fxst
    hello all i have a 2001 dyna with  a hd tacko that only works intermittantly any ideas where to start looking thanks fxst
    How intermittent is it ?
    Look at the wiring diagram and check for steady supply voltage across pin 1 + 2 on the Tach.
    Check continuity of the pink tach signal wire from pin 3 of the Tach to pin 12 on the black ignition module connector.
    If this checks out, it may be a faulty Tach. Likely not easily repairable if at all.
