2010 solo seat.
  • Neale
    Neale
    Hi, can anyone advise me if the seat from an 010 48 will bolt straight onto my 010 883 Custom. Thanks in advance.
  • Neale
    Neale
    Or..... The seat from a 72. I have a solo seat that came with the bike when I bought it but I'm not impressed with the look or comfort of it.
  • shadowarrior
    shadowarrior
    Yeah they should fit if its the 2010 models I think. Look at Mustangs if you want comfort, Le Pera if you want looks.
  • TC883
    TC883
    Yes it will fit. You may need the move the rear screw in anchor point to the forward position in the rear guard, but that is easy to do. Cheer, TC
  • Neale
    Neale
    Thanks gents.
