External Breather Kit
  • Sparra
    Sparra
    I have been looking at DK Customs external breather kits...I have a K & N air filter on my bike that uses the standard backing plate...At the moment the breathers work with a rubber gromett with a tail that runs down a molded recess in the backing plate to down into the air intake. If I use a DK Customs breather kit that taps into the backing plate how do I block off the hole and recess where the breather pipes now run??? Hope this makes sense..
    Cheers...
  • Big Steve
    Big Steve
    I've seen a blob of silicon used, but why not spend the extra pennies and get the DK intake as well? (Happy with mine BTW)
  • Sparra
    Sparra
    Thanks for the reply's,I'll have a bit more of a think as DK Customs want $69.00us to ship one out to me...
    Cheers...Sparra
  • Sparra
    Sparra
    All sorted,found some oil line in the shed and an $8.50 brass tee. All hooked up and run down under the frame and stops near the kick stand..Just vented to the open for now until I find a small filter..
