Online: BigKangaroo
Retune
  • AlHD48
    AlHD48
    Hi All
    I have a sportster 48, been dyno tuned at Eastern big twin , Was thinking about putting the standard exhaust back on , I know it needs to be retuned. Can this be done by myself , I dont really want to pay another $700 to get it redone. I have a SERT .
    Is it hard to retune yourself ? I have never done this
    Thanks Guys
  • Retroman
    had an EPA notice have you ?
    DO NOT retune to fit your stock exhaust system
    It will run fine enough for your purposes ( whatever they may be !)
  • AlHD48
    AlHD48
    no love letter , just was thinking about it .
    It would run a little rich if anything so no problem. Its the running too lean that is an issue.
  • AlHD48
    AlHD48
    is too rich, too much fuel ?
    too lean, not enough ?
    Right on. Lean is bad. Too rich can be bad too. Why would you want to put stock pipes on if you don't have to? There are performance exhaust options that are between stock sound and obnoxious loud if that's what you're after
  • robots
    robots
    you wanna knock about 5points globally off your ve tables, check for knock then could take another 5 off if nothing
