Online: speedzter
Please help me identify this handlebar
  • shadowarrior
    shadowarrior
    Hi Guys,
    Can someone please help me identify the handlebar fitted on this guy's 1200C? https://www.youtube.com/watch?v=jtdITuhOvIU
    In search of a comfortable handlebar to replace the stock ones.
    Cheers.
    There just Drag Bars, I sell them here are VPW $75.00 03 8405 9212
  • shadowarrior
    shadowarrior
    Thanks Walka! Yep they are the same bars! Now to research bit more and see if a 10inc mini ape will be more comfortable or the drag bars. I have the built in bar clamp so don't think I can use most of the standard risers.
  • AlHD48
    AlHD48
    I recently installed 10 inch mini apes. Tgey are more comfortable
  • Pedro123
    Pedro123
    Gotta agree with AlHD48, just put a set of Scorpion mini apes on and it's a totally different bike to ride. Soooooooooooooooooo comfy!
  • AlHD48
    AlHD48
    I went with the harley chizeled bars. Man what a rip off. But i love them . Do the install yourself if you can. Stealers will charge you a fortune
  • shadowarrior
    shadowarrior
    Thanks guys!
    VPW has 12 inch Scorpion mini apes, I want my wrist to sit lower than my shoulder and bit wide instead of narrow at the center. (am 6ft)
    I should be able to install them on my own, from the looks of it, I'll grab some wire extender kit, a new clutch, brake and throttle cables. Might do it along with changing over to Kurakyn ISO grips.
