Online: speedzter
Custom Dynamics Bullet-Style Dynamic Ringz LED Turn Signal Inserts
  • Hast
    Hast
    Hi Guys,
    I want to install   Custom Dynamics Bullet-Style Dynamic Ringz LED Turn Signal Inserts (http://www.jpcycles.com/product/136-826) on my 2017 Sporty.
    Does anyone know if having indicator lights as running lights at the same time will be an issue in Queensland? Anyone with these already installed here? I would like to know if three are any issues i.e will the indicator self cancel after completing a turn,  any issues with arming the alarm  (lights blinking when armed), overall brightnes.
    Would be good to hear others' opinion before spending $ on the lights.
  • Hast
    Hast
    Hi Bonkerz, thanks for fixing up the link.
  • robots
    robots
    yeah i run them in 2010 fxdwg, they plug in to bulb socket then you use posi-connectors for the running light feature
    very bright and no lost led's after about 3 years, i believe the main requirement for your turn signal is to have orange indicator
  • Hast
    Hast
    Hi Robots,
    Thanks for your input mate. What do you mean use "posi-connector"? is that to disable the running light feature? Do the blinkers operate same as the stock ones i.e. terminate after completing a turn and blink when arming/disarming the alarm?
  • robots
    robots
    everything operates as normal, no fast blinking, they are very bright and well worth the money
    you use the posi-connectors to tap the wires from the CD dynamic ringz into the rear brake light wire
