Online: Hilly, pat
Sagging foot pegs
  • AlHD48
    AlHD48
    Hi All
    Has anyone out there have a sportster with sagging foot pegs, mine sag which sucks , the clevis is really strange as it is not equal lenghts , bottom part is shorter .
    does anyone know if anti sag d cips work or do i need to by new clevis's ?
    please see attached pic
  • brash
    brash
    Mine have done it aswell, I originally thought it was because I was running Brass pegs and they had worn eventually, but they were square when inspected.
    I ended up shimming them with some fine slithers of sheet and epoxing it on, as dodgy as that sounds it's held for 5,000km's and took all of 5 seconds to do.
  • AlHD48
    AlHD48
    Hi brash
    Thanks for the info. So it was the pegs for you. Might be the same for me. I got some new ones coming in the mail. Hope it fixes it
  • AlHD48
    AlHD48
    Thanks bonkerz. Its crazy america sells them for 1.99 here they coat 13.50 plus postage all up $20 lol. Go figure
    purchased them anyway, hope they work
  • AlHD48
    AlHD48
    Well guys its the peg mount that is bent. Bottom part on brake side. just purchased one from hd , and have to chop it to fit new pegs on .
