Online: 1423, Rextheute2022
2016 iron 883 ABS brake line swap shouldn't be difficult right?
  • mrjessehlee
    mrjessehlee
    Hi guys, my first post here.
    2016 883 rion.
    So I found the brake line that will fit my new handle bar.. How did you guys to the bleeding for the ABS module part?
    is there DIY instruction anywere? or take it to the stealer?
    heard it needs to be plugged into the computer of some sort. not sure if this applies for 883 iron also.
    Thanks a bunch.
