Online: baldy1450, Hilly
hey guys please help what this called?
  • Shaneskyline
    Shaneskyline
    Hey guys i couldnt find anywhere what this circle part called.
     i need to replace this cover on my street bob 2012.. i couldnt find information anywhere so i thought to put it here. any help would be appericate thanks
  • spacewolf
    spacewolf
    I noticed that exact bit had come loose on the wife's Low S as well. Clipped it back on before it fell off. What it is called tho I have NFI.
  • fat103
    fat103
    ABS
  • limpn
    limpn
    Abs cover $9 bucks from Frasers
  • bobby bob
    bobby bob
    sounds like these covers are designed to fall off, nice little extra earner for HD.
  • limpn
    limpn
    yeah ive had to reaplace 4 now in under a year.. little plastic tabs hold it on and just rattle off or the tab cracks from the heat and vibration ... ended up putting some bluetac on the underside of it .. so far so good been on for approx 2200ks
  • Damo14
    Damo14
    Mine fell off about 6 months ago and I never replaced it
  • Iron
    Iron
    mine rattles and is probably going to fall off :)
  • Far Canal
    Far Canal
    Sounds like they need to be glued on for extra holding power.
  • Wimbo
    Wimbo
    I'd just take it off. Too many extra bits on the bikes these days that you don't need.
    My Suzuki LC had some stuff on it like this 20 years ago and I took it all off.
    Now its a Bobber, hehe.
  • Ando
    Ando
    10.76 pass down the drags mines never moved
  • blueystar
    blueystar
    not bad got a timeslip
