Online: 1423, Rextheute2022
Putting 1" axle wheels on an old 3/4
  • mutley
    mutley
    Ok heres the deal guys i have some late model 1"axle wheels to replace my rusted 3/4 axles wheels so whats the best to do get  bearings same od to 3/4 id or sleeve it down  do HD have such bearings or bearing place? some one must know the way to go so lets hear it guys
    smut
  • Hound_Dog
    Hound_Dog
    Look on eBay mate. There are kits to take 3/4" axles to 1". I would go in reverse though. Better, bigger bearing. I just did 2007 SG wheels onto a 92 Fatboy for a guy. Remember these are proprietary bearings and not available at a regular bearing shop.
    Converted 3/4" Axle Rear Wheel Bearing Kit Harley-Davidson Replaces OEM 559339.....type this into US eBay
    Or this for reducers. Wheel Bearing Reducers 1" to 3/4" Axle Reducer Spacer for Harley Wheel Bearings
  • mutley
    mutley
    thanks hound dog
    Yes you can get wheel bearings to suit from a decent bearing supplier I get my bearing from bsc or statewide bearings
    Here in Perth I normally get Nsk which are far better than the harley ones and at $7 or $8 buck will out last the $25 harley ones Hands down or I have used on one of my bikes the Vulcan engineering axel reduces as there stainless so won't rust to
    The bearing or axel And depending which way you go if you swap the the size of the bearings you will need to swap out
    The bearing spacer in the center of the wheel as can't use a 1 inch with 3/4 or 3/4 with 1 inch bearings and if use the adapters
    You will have to machine down your external wheel spacers and also the 3/4 to 1inch are slightly thicker as mentioned
    So is a bit of stuff around but do able
