bike is booked in for......
  • Odin
    Odin
    I have booked my Street Glide in for some SE 204 cams. Should be done in a few weeks. Will post the figures and dyno sheet when done. happy days ahead I reckon.
  • markwoumla
    markwoumla
    What year, and motor size Street Glide do you have Odin ???? And are you doing just cams ???? No doubt you have a stage 1 at the moment !!!!
    I am tossing up throwing in some cams in my 2015 Street Glide, stage 1 .... the se204 are in the mix ..... So many to chose from that are similar ,, these or similar proven cams, with a good tune will put a smile on your face .....
  • Spook
    Spook
    Why?
  • Jetta
    Jetta
    Good choice of Cams for a 103 man. Well done Chris. blushsmiley
    Speedy, fuck off the adults are talking and you don't even have a tourer.
    Now back on topic: odin we've exchanges msgs about the cams but I wasn't aware you had the 103 ho engine which has a slight increase in compression and cams close in spec to the 255. I've heard the ho engines go alright in stage 1 spec with a good tune so I'll be curious how much improvement you see with the 204 cams. Nice improvement on my normal 103 engine with the 204 cams.
  • mickle
    mickle
    I am waiting for someone to ask China about cams, his pulls as hard as my 110.
    China's dyno sheet was better than mine but diff dynos and I didn't realise at the time but I had map sensor issues with mine at the time which has since been fixed/replaced and been re dyno tuned. I just didn't get a new print out but bike runs well. I should chase up the later dyno chart. Bike runs so well I needed to upgrade the clutch diaphragm spring
  • Odin
    Odin
    forgot to mention the cost of getting the 204 cams done. $1650 and this includes dyno tuning
  • Odin
    Odin
    well the results are in.
    had the 204 cams installed and dyno tune got 95 horses and 107lbs.
    Very happy with the result. Pick the bike up tomorrow. While it was there I had the audio system upgraded with 300w amp and new fairing speakers installed. Harley part # 76000410 for those that want to check it out.
    will post my thoughts on the "seat of the pants " feel
  • markwoumla
    markwoumla
    Sounds good Odin ,,,, look forward to your seat of the pants opinion .... And a peak at your dyno sheet, to see were it all happens would be great ... Cheers
  • Odin
    Odin
    this is my dyno sheet, click on the pdf to see
    dyno_sheet.pdf
