Online: tussuck, blueystar
Attitude Wheels from VPW
  • M2saint
    M2saint
    Hi all just wanting some info about fitting attitude rear wheel to my 2012 Fatboy import so no ABS and 25mm axel.
    Wanting to know if anyone has fitted a set previously I'm trying to fit 18x5.5" just can't seem to get the spacer size's right and it's driving me crazy... thought I had them spot on only to tighten the axel bolts and find the calliper mount is touching not worried about lining up the pulley with belt as it's easy enough. Tried PVC pipe trick seemed to work had spacer made up looked all ok till I tighten the axel up I reckon I'm only a mm out some where as I can move the wheel when it's tightened up but it's not free at all.
    Really after someone that's fitted one and what size spacers they used.
    Thanks in advance for any help it's much appreciated cheer fellas.
