Online: vitalhempbuys
Stage II on 2016-2017 Roadster
  • Rubberneckin
    Rubberneckin
    Hi Guys,
    getting my bike next week, will update with Photo. Besides the Stage I that i am already getting, the delay for the bike is my last min add on, getting a Stage II Kit in it. i am super excited!!!
    anyone else out there done a Stage II on a Roadster? Is there a big difference in power? What would i be expecting in HP with the Stage II
  • AlHD48
    AlHD48
    probably not the best if you are getting a canned tune from a harley dealer.
    If I were you I would be a dyno tune from a good tuner , makes a world of a difference
  • Rubberneckin
    Rubberneckin
    Good point, once i get it, i will bookin for a Dyno then i can compare what power i will get with the CAMS (Stage II) upgrade.
    See how harely tune compare to a proper Dyno tune she will get out if it.
  • brash
    brash
    I didn't do a SE kit, but rather went my own option.
    Hammer .570 cams
    maintained all stock valvetrain, base circle smaller than stock so slid right in.
    Tuned myself via Powervision (with a bit of help from a Tuner) Made 87rwhp.
    Supported with Bassani Pro Street 2 into 2 and Joker Machine 4 inch air cleaner.
    A good 2-1 pipe would net 90hp I think, but I like the look and sound of a 2-2.
    A canned tune with a Cam is a recipe for disaster, there is no "do it all" tune no matter how many they reckon they have done. Every engine has it's own volumetric efficiency of sorts.
