Online: Hilly, speedzter
Fuels
  • bravo
    bravo
    Has anyone run avgas in there bike (carby models) I was thinkiong of running 50/50 mix of ultimate 98 and avgas which is 110 octane. Has anyone done this?
  • SuperGlide
    SuperGlide
    i ran a 13.4 at WSID the other day,
    now I bought a bottle of octane booster for $12.00 so should be good for mid 10's?
  • bravo
    bravo
    just for a couple extra ponies and i get the fuel for free. the engine is a 88cube with no mods. the only real trouble i see with it is the avgas contains lead, and the engine will need a tune to stop pinging
  • Phillthy
    Phillthy
    I get worse fuel economy running 98 than I do running 95 in my bike.
    All you will do is throw fuel out the back of the bike thats not burnt properly.
    You would need a serious motor to run that fuel.
  • shadowhand
    shadowhand
    It depends on how the bike runs. If it runs good there should be no problem. However what is used in the fuel to get the high octane rating? If it's ethanol/methanol there might be a problem if there's too much of it.
    I'd mix the Av Gas with regular unleaded.
  • Hoodaman
    Hoodaman
    Ride it at 35oooft and you should feel what avgas is designed for.................
  • whiteyluvsrum
    whiteyluvsrum
    ok, the dealer told me to use 98, but a quick look at the manual it says 91 (95 RON).
    which one is better for me train?
  • czarek
    czarek
    Whitey - the manual says 91 but that is in US rating which is equivalent to roughly 95 - 96 Auzzie octane.
  • bravo
    bravo
    my main concearn was the lead content in the fuel.
  • kingchops
    kingchops
    I just managed to fix my pinging issue that I' ve had for a while since I fitted the Thundermax. Admittedly I've been pretty slack with it as it wasn't that pronounced. But I did notice it a lot more at higher speeds on our ride to Edenhope. I just took off 1 degree of timing from the Timing vs Engine speed map which takes a degree of timing off across all the rev ranges. That fixed it, there wasn't any noticable cost in performance either.
  • wildchild
    wildchild
    So down to the guts of it all, what is the correct fuel to use in a 96 Cube.
    WC
  • wildchild
    wildchild
    balls of aluminium on the plugs Scotty, that does sound real good. And thanks for the info on the fuel, I am using 95 at the moment and all is good.
    WC
  • shadowhand
    shadowhand
    95 & 98 are the best but I use Shell or Caltex regular & never had much of a problem since the bike was re-jetted, I mix premium in when I have the cash & the engine works better. If you live in the bush (who's gonna pay 10/12 cents more a litre for 95?).
