Online: vitalhempbuys
Predator Engine Mounts
  • daccadan
    daccadan
    Hi Guys-------has anyone heard of or fitted Predator Dyna Engine Mounts to their bikes. I can get a pair for around $530 delivered.  I would have to fit them myself.
    Are they worth the investment for a 88ci Twin Cam or are they really suitable for high HP bikes?
    Ive heard they eliminate the need to fit True Trak systems and the like and that they eliminate engine vibrations to the rider.
    Any thoughts ?
  • Lushy
    Lushy
    They are excellent.
    *walking away*...
  • DarKasH69
    DarKasH69
    I had a mount given to me to trial, by the Company a few years back. I did 75000km with it. Was a great unit in itself.
    It did wear out over that time. Didn't feel it happening as it happened slowly.
    I since refitted an original front mount and it felt alot better than the worn predator unit.
    So .... if you don't intend to do more than 70000km then use them. They RE great. .. like anything , they will wear out over time.
    In its prime,, was better than original.
  • limpn
    limpn
    heard good things about them i was thinking of getting a set when my OE ones wore out...
