grumpy sportster
  • patches
    patches
    hopefully you guys can help me. i have a 2014 sportster 1200. Vance and Hines slip on mufflers, screaming eagle air cleaner, remapped efi with a harley tuner. great under full throttle or no throttle. the problem is in the middle or "partial throttle", like when backing of a little for a corner. bike starts to surge, run rough and even misses. any ideas on how to make this thing apleasure to ride. thanks for your help
  • Daggs
    Daggs
    Has it just started happening or just start happening after one of the mods or always been like it ?
    you aren't in too high a gear for your speed at these partial throttle times?
  • patches
    patches
    Bought the bike only recently with the pipes and air cleaner on it. Bike ran a little rough like it needed a tune up.
    Had the efi remapped. Dealer recommended it to fix the problem.
    Made very little difference to the bike. Still has the problem just uses more fuel.
  • brash
    brash
    Dealer tune... there is your problem.
    What state are you in? A proper dyno tune worth the $$$.
    If the problem is partial throttle then it could be the throttle position switch.
  • patches
    patches
    In NSW. The dealer offered to do a dyno tune for around $450.
  • Daggs
    Daggs
    No, get it to a reputable independent dyno tuner.
    The dealerships aren't known for their outstanding tuning.
    It's worth it. 900 k round trip for me but I don't hesitate to do it
  • patches
    patches
    Thanks for the advice, will research where to get it done.
    Are there any decent ones in the new england. Or mid north coast areas.
  • patches
    patches
    Thanks tussuck will investigate the switch.
