Freedom turnouts
  • limpn
    limpn
    Hello ladies and gents ,
    last weekend i took my bike through the Royal Natho Park south of Sydney for a spin with my VH big radius 2 into 2 ... ever since i had the bike the front pipe on the first bend near the forward controls i use to scape the hell out of it... well last weekend it finally decided to snap off completely heat sheild and pipe.. the pipe then decided it would tilt downwards and dig into the road.. the end result was the the whole pipe went boucing off the bike and into the bush.. (couldnt find it and lucky there was no bush fire )
    i have always been a fan of the turnout pipes.. i found Freedom made a good set and after a few youtube clips i decided i would go ahead and buy them... $999 delivered to my door i thought was pretty cheap ...
    put them on and straight away its a different note to the big radios alot more deeper note and they dont have that tinny noise either...
    only down fall is the lower pipe scrapes on most roundabouts on the turnout section only at the back. so far the front section that scraped on the VH it doesnt touch there ...
    very happy with them easy to install looks tuff sounds different
    8/10
  • Lowrider762
    Lowrider762
    Hi I fitted a set to my Dyna and loved the sound and they are good quailty pipes.
