Side mount licence plate breaking-Dyna
  • musty
    musty
    Hey guys,
    I have an issue with the HD side mount licence plate on a 2014 FXDB.
    The pivot pin that holds the licence plate to the mount keeps dropping out. I had the first one replaced under warranty, fitted the new one and its lasted 500kms when the pin dropped out and the entire licence plate broke off at 100km/hr, lucky it didn't hit anyone behind...
    Has anyone else had problems with the HD side mount plate?? or maybe i've had 2 dud ones??
    I have the chopped fender so I kinda want to keep that look..
    Thanks in advance.
  • musty
    musty
    Ok, thanks Hot and Heavy...
    I must have something going on to have 2 break in 1000kms..
    The picture attached shows the problem pin that drops out and this time it fell out completely and also lost the retainer tension spring inside. I managed to retrive the actual licence plate part from the side of the road.
    Guess I'll be going back to the dealer again on Monday..
  • Wimbo
    Wimbo
    Thought that was illegal?
  • musty
    musty
    Regs say from a distance of 20m you must be able to read the plate within 45 degrees.. HD sidemount easily meets that requirement.
  • Wimbo
    Wimbo
    Ohh, maybe its just NSW then, I would much prefer to have the plate on the side.
  • Wimbo
    Wimbo
    Actually, a copper could complain about not seeing the plate from the extreme angle of the other side of the bike.
    I think I remember this being mentioned before.
  • Sparra
    Sparra
    When I bought my bike off the fella that bought it into the country it had a side mounted plate the same as above and was registered in NSW...I took the ugly looking thing off...
  • musty
    musty
    Just for the heck of it, I'll measure it up with the 20m / 45 degree thing and see if it's visible from the right hand side.. it should be, the bloody thing sticks out far enough.
  • musty
    musty
    Motor Head, Where did you put your plate? I've got a chopped fender so I don't really want to use the ugly plastic plate holder that attaches to the rear of the guard which makes it look like a full fender anyhow.
  • Wimbo
    Wimbo
    Ohh, I see. Its attached horizontally, not vertically. Vertically must be against the law then.
