S&S Stealth Air CLeaner
  • robnicko
    robnicko
    Couldnt find a review on the forum for these so thought i'd write one as I put one on
    Quality & fitment 100% + I wanted to retain the stock cleaner cover football thing
    Bike has the S&S tapered mufflers and 13.8:1 XIEDS & now the cleaner.
    Differences noticed so far are, lots more low end torque, smoother much more responsive power delivery and prior to this I had a bit of decel pop which has now dissapeared. My thinking is that with the pipes & XIEDS there was exess unburnt fuel in the headers and now with the extra air its burning more efficiently.
    I have checked the plugs after a 200k run on the weekend and they look great
    Overall, extremely happy with this setup however will be looking at a proper tuner SO do I go Powervicion or SESPT?
    I do not reallly think I'll mod the bike much more except possibly cams but for now would like advice on the tuner ?
    I'm leaning towards the PV mainly for the ease of tuning (no PC) and quite like the gauge options so I can see in real time whats going on.
    rob
  • Gnoo
    Gnoo
    If you're only leaning towards the PowerVision,,,,then,,,
    you haven't finished your research.
    PV offers so much more and you are on the right track.yes
  • Retroman
    Where in Australia are you robnicko ?
  • Retroman
    Can't help you with the Powervision ( but lots on here can !)
    All the best with it
  • robnicko
    robnicko
    no worries Retroman,
    pretty sure I should be right....i hope !
  • Gnoo
    Gnoo
    You will be Rob.yes
    Thundermax here!
    Personally I hate the football look so have a custom I made on the sporty and a S&S teardrop on the other bike.
