Online: obisteve, B1ack, HD17, John.R
how to wind up suspension on a breakout
  • bloodog
    bloodog
    Just talked to a guy about his breakout { for asle } he has it lowerd with 260 fat rear
    I asked about scraping on tight turns his reply was just wind it up before going for a ride
    You mob cool with this.... is it that simple to do on a breakout
    Thanks bloodog
  • Far Canal
    Far Canal
    Depends on what sort of shocks it has.
    Some rear shocks have a remote knob that wiil raise and lower the ride in a jiffy, easy as pie. If his bike has those kind of shocks I guess it makes sense.
    If they are the type you have to adjust manually I reckon you would get the shits with doing that pretty quickly.
  • bloodog
    bloodog
    Thanks Far Canal
    I will ask if standard shocks
  • Far Canal
    Far Canal
    How do you slam/unslam the type of shock your dealer was talking about H&H?.
    Is it even designed to be ridden on the low/slam position?
  • bloodog
    bloodog
     Bike has a Lowering kit, but I will ask him just what it dose, type and so on
