Online: B1ack
Modular/Flip Helmets
  • Marz
    Marz
    Looking at getting one of these new fangled modulars for long touring days,  Always used open face on Harley.  Full face on supersport.. always used SHOEI mainly. (but not brand loyal) Before you suggest to use search funtion, already did that, nothing really current as of 2014.
    Any suggestions recommendations?   FIT, SIZING, COMFORT, NOISE and other issues...?
    I like the look of the Shark Evoline 3, chin bar to the rear, certified as full face and open face, thats gotta be a bonus right?
    Never tried one, but I know people who rave about the 3s - way lighter than the previous model and the best of both worlds when going on long rides..
  • Chaser
    Chaser
    The best one is the one that fits! Go into MCAS (but not the crap Auburn store) and try a heap on.
  • Carmo
    Carmo
    I use a Bell Revolver Evo in matte black with a tinted lens and it's bloody brilliant. It's a good quality, under $300 and I don't have anything bad to say about it. I'd recommend checking them out
  • skirtster
    skirtster
    I have a shark evoline 3, I feel it restricts your side view with chin bar down. I only use it with chin bar back which is an ugly looking helmet.
  • Fatboy80
    Fatboy80
    I have the evoline 3 its quite heavy and as skirtster said it does feel restricted in vision, also the main visor rattles at any speed over 20k on an ultra, if you know someone with one that they might let you try I wiould advise before sheeling out, I very rarly use mine now
  • Marz
    Marz
    Thanks Carmo... will have a look at Bell.. hadn't considered them thanks for the links to your vlog..
    Skirtster and Fatboy... thanks for the tips
  • Krackers60
    Krackers60
    I've been using a Shark Evoline series 2 for three or four years now on a Street Glide with varying screens without complaint. It is the only one I use.
    Around town, including 80k zones, metro and country I'll have the visor up without issues.
    I use the chin bar on on very cold days or when it's raining.
    For me it is a great helmet and I wlll get a series 3 when I need to get a new helmet.
  • Marz
    Marz
    Thanks China... C3 Pro looks great... what did you use for sizing... your old helmet or the charts on the website.
    Thanks for the link yes
  • potluk
    potluk
    Have a look at Rjays Navona. I love this helmet; open face when your putting around and shield down when your out in the open. No issues with fogging up or having to twist your neck off to see stuff beside you properly and a good price also. Has a half tinted screen that flips down if you really need it ( i have only used it once riding straight into the sunset ) and quick release strap ( you can put it on or off with gloves on ). If you ride to work in daylight and come home at night you dont need two sets of glasses like an open face and it doesnt try to pull your head when your slightly above the speed limit ( not that we do that ). Only issue i had with mine when i got a screen on my dyna the buffering seemed to push the shield up not from the bottom but more from the top but i just tightened the screws on the screen and havent had any problems since. well worth a look. Hope this helps Cheers Potluk
  • Far Canal
    Far Canal
    Excellent write up, cheers for that.
    The 86 dB noise rating has me completely stumped though, if that is the noise level you experience in a normal car then I don't understand why my Husqvarna chainsaw has a 76 dB rating. It seems 50 times louder than any car I have been in.
  • Far Canal
    Far Canal
    My typo, but that is still 6db louder than a small chainsaw. Something is awry there. Not saying you got it wrong, but someone must have.
  • Far Canal
    Far Canal
    Do you wear earplugs under it ?
  • boxa
    boxa
    I've got , a shoei i full face i bought for long distance , a open for around town , a nolans with a flip up screen , , for everday use ,, just bought a rj's 3 way with the internal visor ,, its the best and the favorite i wear it all the time now
