Online: B1ack, B0nes
21" abs issue
  • limpn
    limpn
    Hey guys , today I finally got around to installing my 21" wheel on my Dyna
    I'm now having issues with the ABS light / brakes pulsing . I also upgraded the triple trees to wide glide ...
    Can you recalibrate the abs module or what else can I do
  • Sparra
    Sparra
    What wheel did you put on it?
  • limpn
    limpn
    Vpw many spoke 21x3.5
    I think it's the abs module has picked up wrong size just wanna know if you calibrate the module ?
    All the google searches come up with us disconnect the abs which I don't really wanna do
  • FXST11
    FXST11
    With ABS you will feel a slight pulse, ( eg; while sitting at traffic lights holding front brake on,) The ABS works via a sensor on axle, maybe you have not sat it right, Maybe have a look at that.
  • limpn
    limpn
    Abs pulsates all the time now feels like it's kangaroo hopping to a stop .
    Read the forums no real answer some stay calibration of abs module other say disconnect the front abs
  • Sparra
    Sparra
    Did it come with ABS bearings??I guess if it didn't you would have noticed it when you put the wheel on but when I put an ABS wheel on my wideglide it fitted even though my bike doesn't have ABS..There is only a few mil difference in width between the 2 bearings..
  • limpn
    limpn
    Wonder if I can reuse the stock bearings out of the 19"
    The ABS unit can be re calibrated by you Harley Dealer
  • me_ashman
    me_ashman
    You need a new bearing...I wasn't aware hd could recalibrate the abs module though? I bought a tracmax module.
  • limpn
    limpn
    UPDATE.. ISSUE IS FIXED ..
    i placed a new bearing in still same issue... i ended up forking out 139 bucks for a wide glide abs sensor as glides come out stock with 21" .. fixed my issue...
