Online: DIVOT
Harley EFI tuning 2001 to 2016
  • Retroman
    UPDATE FROM MY OLDER THREAD
    I can help with advice / recommendation and " how to " with ECM/EFI retuning / reflashing for any fuel injected Harley 2001 to 2016
    These model years up to 2014 are well out of warranty , so there will be no " warranty grief" with the dealers if I do it for you.
    AND YOU WILL SEE IT BEING DONE WITH EXPLANATION ON THE WAY
    Recent Yank "Grey imports" have become somewhat of a speciality of late , as they are all EFI bikes
    For the most part I use original SERT and later TTS or SEPST Supertuner Pro and guide you thru' the maze you need to negociate. ( takes a wee bit of learning !)
    I can also use the Supertuner tuning dongles ( AKA the current Screamin Eagle race super tuner ) if you have one already.Up to 2016 models
    I have all the combinations of cables for each model year AND CAN RECOMMEND WHERE TO PURCHASE A TUNER IF YOU DON'T HAVE ONE ALREADY !
    Still doing this , now up to 2016 models using the HD Supertuner pro
    I have done 4 bikes in just the last week. A 2007 using original SERT , 2009, 2012 and 2015 using Supertuner pro
    The 2007 Nightrain had a 1690 Super high output kit ( AKA stage 3/4 ) in it and had NEVER been tuned for it.
    The bike is now smoother and faster with way better fuel consumption.
    PM for contact details
    Listed in the WA forum as obviously it's a local thing !
