Online: Soapbox2627
mechanical noise when cranking over 88 evo
  • ashp
    ashp
    when starting my 88 evo i get a horrible noise like it is not engaging properly. any ideas?
  • AJ56
    AJ56
    starter gear not engaging the ring gear. Take the primary off and watch what happens when you try to start it. (Take out the plugs to make sure it doesn't start but still turns over.)
  • Kato
    Kato
    Im afraid AJ56 is spot on
    Is it a costly thing to fix as my 03 Fatty does the "noise" that you refer to ashp but its once every 10th start (sounds like shit though)
    I have always though iy=t would cost a bundle and if it only happens every say 10th start ..............put up with the noise as once I stop and restart - happy Days
    Id be interested AJ56 in your thoughts repair wise
    Might be as simple as a bad starter clutch. If so, an easy job.
  • swamprat
    swamprat
    sounds like starter clutch , ive had to replace mine a couple of times on my evo
  • AJ56
    AJ56
    If it is the starter clutch an easy fix to do it yourself rather than donate money to a dealer. Hopefully not much damage has been done to the ring gear. Not an expensive fix either if you do it yourself.
  • ashp
    ashp
    cant do that bro because there is a needle bearing in outer cover which supports starter shaft
  • ashp
    ashp
    can't do that bro there is a needle bearing in outer cover which supports starter shaft
    Since when do thay run a needle bearing .? It should be a bearing bush in the outer cover In which the jackshaft slides in to when The starter is engaged
    bush is 1987 &up models
    That's what I thought he says it's a 88 softail , I thought the earlier shovel/evo and sportsters
    had needel bearing in the primary
  • bobby bob
    bobby bob
    Bush in my 87 outer primary
    Ditto on my 86 FXR... needle bearing to support the starter shaft is in the outer primary.
