Online: beaglebasher, Hilly
Chrome cleaning
1/3
  • blubarb
    blubarb
    I have heard that Autosol might be too abrasive to use to clean new chrome, any views on this? Perhaps Autoglym might be less abrasive?  What do you use?
  • phat-boy
    phat-boy
    i use that formula one cleaner in a can   spray a bit on a cloth, wipe it over then polish off and comes up great. got a deatailer that comes out every second month and his stuff is pretty good but took all the stickers off my gixxer and his product could not remove all the residue but i used my own and it bought it straight off. does not leave a film but next time you clean your bike it seems a lot easier.
  • jim76
    jim76
    I use window cleaner n a soft rag does a good job, if there is rubber marks from boots on the pipes i use a bit of penatrating fliud n super fine 0000 steel wool can pick it up at hardware store (the stuff they use to restore old furniture DONT USE the dish ones there to rougth)
  • groover
    groover
    Wax and Polish as I dust with Mr Sheen
  • Kustomtown
    Kustomtown
    For blue pipes I use 'Blue Job'
  • Hoodaman
    Hoodaman
    Just what I was lookin for kustom........tank yoo....
  • Kustomtown
    Kustomtown
    No worries, Hooda.
    Ebay has some now
    http://cgi.ebay.com.au/Blue-Job-Exhaust-Chrome-Cleaner-for-all-Motorbikes_W0QQitemZ190258809119QQihZ009QQcategoryZ35229QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Kustomtown
    Kustomtown
  • Danaj22
    Danaj22
    Blue Magic Metal Polish is another non-abrasive metal polish.
    It is beaut!!
  • GB
    GB
    You guys.... black is the new chrome!!
  • Danaj22
    Danaj22
    so use the Blue Magic Metal Polish to shine up all your spiffy black metal bits,
    beeaauuttiifffuull!!
  • Peter
    Peter
    Mr Sheen for chrome and Purple Polish (great shit) for alloy.
  • Tbolt
    Tbolt
    i use purple polish, really good stuff.
    but i might try some of the other products mentioned
  • Wideguy
    Wideguy
    Eucalyptus Oil for removing glue and boot rubber. Apply and let it soak in for a while and rub off with a soft cloth. Got rid of the reflector glue AND the missus' boot rubber from the pipes. Not a polish though.
  • Cyborg
    Cyborg
    Use Burnishing steel wool, it will take of anything but it isn't a polish it just gets rid of the crap.
  • FXD09
    FXD09
    Mr Sheen
  • hd888
    hd888
    Have to agree, Mr Sheen for me too. Use it on everything.
  • EarlofT
    EarlofT
    Meguires Chrome Cleaner ....... I see a few are using Mr Sheen, interesting . does this not
    leave a film once apply ?
    Cheers and safe riding
  • kiteman
    kiteman
    I've been using Autosol for years but only for "spring" cleaning. If you live near the coast the salt air leaves little pin-prick sized dots on your chromework over a period of cool days and nights. The regular chrome "shiners" don't get rid of these. The Autosol works superbly without the need to rub hard and the result is stunning. I would suggest NOT rubbing really hard on thin chrome fittings like axle nut covers where the chrome is not so thick.
  • Panchop
    Panchop
    I use a product called Wicked metal polish, relatively cheap and easy to use
1/3
