GAZZI SHOCKS
  • boxa
    boxa
    Anyone know much about them ,, local suspension specielists  says he will not fit ikons , hagons , progressive , reckons there cheap and nasty , He reckons Gazzi are probably the way to go , he said there very good and there cheapest are still better than the others dearest . Anyone had experience with them
  • TJU
    TJU
    Carnt tell you much about the actual shocks ... But from what I have been told one of the
    Owners is a guy who had an engineering shop down Albion way here in Brisbane ,
    Really nice guy , seemed to know what he was on about , did some nice work on one of my old
    Z1000's back in the day .
    Memory is pretty bad these days , I think his name was Paul Bussell , Bussell Engineering
    Don't quote though .
    Have to say find it a bit strange Progressive Suspension getting such a bad rap from
    Your local guy ... I can't fault them ... Of course there are far more expensive items out
    There like the Fornellies , the French guy from Tassie ... And others but Progressive
    Over standard any day for me .
    Let's us know what you end up going with , cheers .
  • HIALEAH
    HIALEAH
    My local dealer had nothing good to say about Progressive or Ikons as well, Reading on the U.S Forums Progressive aren't what they used to be, I went with Bitubo pricey but worth every cent imho
    get another dealer as he is talking chit! Ikons are very good
  • wazza430
    wazza430
    Just fitted the Progressive front and rear on my Deluxe. Went the heavy duty but shouldve gone standard. The bike is now very stable when cornering over rough terrain.
    Nothing wrong with Ikon,,, Your guy is a dick head
  • JFE
    JFE
    A bunch of Sportster riders on this Forum seem very happy with using Ikon's. Worth a Google.
    I take an interest as I want to go that route with my FXDF.
  • Lushy
    Lushy
    I have personally used the Gazi shocks on a few bikes and they seem very good, especially for the money. Nice fat shafts and clean crisp dampening adjusters. I have had to change the springs a bit on them, but overall I like them. Koni/Ikon are ok quality but are a bit rudimentary.
  • boxa
    boxa
    I actually have Ikons on my rocket i put them on primaraly to lower the bike, the ones i bought came 30mm lower than standard, i'm happy with them , I had progressives on my street bob and they shit themselves within 12 months ,, I don't know the guy said the cheaper Gazzi were better than the dearer others , and if you want to spend lots the dearer gazzi were real top of the range stuff
  • graeme
    graeme
    Same happened to me as boxa went thru 2 sets of progressive now have ikons no issues
  • noah
    noah
    84evo , Ikon rebuilt standard shocks a couple of years ago , Daily rider ,Rural area ,Bumpy , Great shockies...
