Online: B0nes
Dyna cranks and farts a lot before starting
  • Darrene
    Darrene
    2008 Dyna supeglide custom, new battery. Standing voltage 12.7, cranking voltage 10.9, charging voltage 13.9 pronblem i have it takes ages to start, backfires, grinds, cranks and takes a while to start. Once it does it runs sweet but quite embarrasing at servo or the pub and it sounds like a sick dog. Just done the 30k service, new plugs, all the oils but this has me fucked and cant work it oout, been doing it for a while now.
    Any help appreciated and thanx in advance.
    Doing it before the service? Does it when it's hot or cold or both?
  • Darrene
    Darrene
    doing it before the service hot and cold, but was showing a mate tonight when cold and fired up straight away, so, i dont know, got me stuffed.
  • Darrene
    Darrene
    Staring simple, I'd make sure the exhaust and whatnot is done up tight, but I'd be leaning towards ignition timing. Someone on here will probably have a better idea though.
  • Darrene
    Darrene
    Yweah a mate said that so i will put the dyna jet tuner on tomorrow and check it out cheers.
  • Darrene
    Darrene
    Sounds like my 2007 Street Bob... it's been like that on and off since not long after I bought her new. Happens more if I try and start her in gear with clutch in. Always select neutral now.
    Was told it was the starter clutch, but I'm not so sure.
  • meddy
    meddy
    Mate had a similar problem on his 99 Dyna, turned out to be a faulty crank angle sensor.
  • binnsy
    binnsy
    Compensator ??
