Online: John.R
'03 Dyna speedo options?
  • Roo Ted
    Roo Ted
    What options do I have for moving the speedo on the Dyna. It sits up too high & looks shit, in my opinion.
    Your thoughts?
    Roo.
  • Methuselah
    Methuselah
    Have seen them on higher risers turned around so they sit behind the bars. Didn't speak to the bloke to see how successful it was though.
  • Ranga
    Ranga
    You can use a XL1200C speedo bucket and mount that moves the speedo from the front to the back of the bars. You will need @2" risers to clear the fuel tank.
    Or you can buy a conventional tank and mount ie Street Bob.
    I've done both and prefer the second method. It is a lot more expensive though.
  • Roo Ted
    Roo Ted
    Cheers guys. Might try the first option, sounds heaps cheaper.
    Roo.
