Online: imoo6170
cv carby evo or tc wanted
  • dynoharley
    dynoharley
    cv carby wanted for client bike , call or message to 0408593476 ,
    i have a complete twin cam 1999 to 05  cv carb set up inc inlet manifold carb with a thunder slide kit & s/eagle complete aircleanercomplete with enginer breather & air cleaner stock cover ,less than 12,000 old
  • dynoharley
    dynoharley
    what sort of figure daddy
    also have a stock cv carb only 100 bucks  ,    for da complete 1 with da thunder slide kit inlet manifold & air cleaner  around  350 buckaroonie's
  • majorboot
    majorboot
    do you have the wide glide speedo still mate?
  • dynoharley
    dynoharley
    wanting it to fit a schovel inlet manifold , would it fit , and how much wear is in the silde area , some realy bad ,
    ring Ian Williams Tuning in S.A. Mic parts Dist, i have his ph # if ya need it , if ya buy da Mic round slide inlet rubber spiggot for a 38m.m or 40 Mic , i forget excatly atm , off & early yammie dirt bike or something like that da 2 bolt pattern is excatly da right size  for your shovel inlet manifold , just blend in da inside dia if needed & a support bracket off da air cleaner backing plate, just had a look @ da carb there is a bit of wear @ da slide , maybe be a new slide could fix it up, ya would have to measure down da body to say ,no play @ da throttle shaft that is da main thing , da other carb with da thunder slide kit has only done 12,000 klm's ,  cheers bob
  • dynoharley
    dynoharley
    thanks bob , will see what owner wants to spend , cheers mate
  • Steve L
    Steve L
    Do you still have the carb and what difference does it make compared to a standard one
    yes still have the carb , what will you be putting it on
  • Steve L
    Steve L
    99 Dyna FXD with a 1550 SE kit
