Removing Security System?
  • Geoff3DMN
    Geoff3DMN
    That's not why I've got an alarm on mine, my insurance company offers and extra 5% discount if an alarm is fitted.
  • kaos1369
    kaos1369
    1 post and he is asking fucked up questions like this, you got a hot one in the shed mate? Give me your phone number and I will answer your question bloke.
  • mutley
    mutley
    if it is a self arming alarm just go close to the bike for it to turn off and while turned off remove the alarm/security fuse and its all over
  • dashsymon
    dashsymon
    I believe the only way to totally rid yourself of it is to replace the TSSM with a TSM and you may need to modify your wiring so the bike will start.
  • dashsymon
    dashsymon
    http://www.hdforums.com/forum/engine...ml#post7910911
    You might want to check this out .... Hope it helps.
