Online: B0nes
FENDER STRUTS
  • bungalow1
    bungalow1
    Righto I've dropped her. What's the easiest/best way to get my rear struts square again. Tyre rubs on one side with two on over some dips in the road.
    No quick easy fix , remove the rear fender and strut covers to see how bent the frame horns are and start from there
    Most Harley's the rear wheel is offset to one side slightly from factory any way
  • bungalow1
    bungalow1
    Perthhog, I've pulled it down and come to the conclusion it is the frame horns not the struts. Out about 10 mm. No idea who would be the best ones to fix it in SEQ. Any ideas out there?
    what model bike we taking about , if t's da frame struts , i just did 1 a few weeks ago 1987 s/tail  , i set da bike up on wooden blocks under da g/box on da  bike stand used a spruit level across da frame where da battery area  is,   straped da bike down to da bench, then use da level to work out where da frame strut is bent , use a bit of heat & a pipe over da job & push it back in possie if ya burn da powdercoat off da frame i use VHT gloss black perfect match for da frame no sweat,  cheers bob
  • bungalow1
    bungalow1
    All sorted.
