Online: Adam76
Banjo Fitting Size
  • AlHD48
    AlHD48
    H All
    anyone know the banjo fitting size for a sportster 48 ? is it 10 mm ?
    the service manual doesnt say the size unfortunantley
    its 10mm
    calipers are 3/8 unf and hand controls are 7-/16 unf
  • AlHD48
    AlHD48
    Thanks Walka , do you stock them for a AN3 fitting ? also do you have them in black ? and price .
    I was told by HD today both banjo bolts were 10mm , ( front caliper and front master cylinder)
    Yes I have every thing here ,
