Replace Mirror Glass
  • weedoman
    weedoman
    Hi All
    The glass in my left hand mirror is smashed. Only recently bought the mirrors so really don’t want to shell out another $120+ for an entire replacement mirror. Any tips on who or how to replace just the glass?
    A glass cutter firm should be able to make some, or better still buy some crappy ones on ebay and use the glass.
  • keith
    keith
    Post a wanted ? on here might get lucky ? Plenty of s#it in sheds.
  • weedoman
    weedoman
    Sorted. Local glass/mirror mob. Cut to size, old glass removed and new glass glued in. 45mins/$35. Happy days.
  • AJ56
    AJ56
    for future reference. If they are OEM mirrors, and they loose their tension on the adjustment ball heat it up with a Hair dryer/heat gun on low and it will soften the glue that holds the galss in. You can then remove the glass, tighten the screw up and then replace the glass after heating up the mirror backing again./ Don't heat the glass but the frame of the mirror.
  • brucefxdl
    brucefxdl
    yep mirror tension trick works,my retainer was rivetted to frame[ '07 lowrider] 1/2 an hour and done.slow saturday.
    Yep same here on a mirror I tried that trick on rivets not screws But I ended up
    chipping my glass so got a new take off set Off flebay for $50.00
