Online: Hilly, Merv
S&S tapered turbo slip ons
  • Fey
    Fey
    Thinking of changing my S'Eagle slip on mufflers over to S&S tapered turbo's. The SE's have a nice sound but just a bit too quiet, Hoping the S&S will improve on this without going to far the other way. Fitting to a 2016 S'Tail Slim. Any thoughts or recomendations? Trying to keep the whole look of the bike close to stanadard cause thats what appealed to me when i bought it.
    You should be happy on all fronts then
  • Fey
    Fey
    Sounds good.
  • robnicko
    robnicko
    I have them on my fatboy, excellent muffler
  • Retroman
    Khrome Werks also do a tapered muffler , works just as well as the S&S.
    AND they have no embossing Logo or trade stamp to alert the polizei whereas the S&S certainly do !
    Rollies in Qld used to be the agent here in Australia
    I had them on a 2008 Softail Custom and they looked like stock , even passed the pits here every year no worries
  • Fey
    Fey
    Thanks. Going in next week for the mufflers. Good to hear all of the above.
  • brucefxdl
    brucefxdl
    put a set of krome works on a 07 dyna good sound[ and picked a up a bit of go on the road too] but not too loud,rollies supplied,retained the look i liked also.
  • HN Man
    HN Man
    I've got them on my 15 Deluxe. Not obnoxiously loud, but cagers know you're there. Mine were also installed with the HD tuner to accompany them. Overall, very happy.
  • Fey
    Fey
    Thanks.Sounds like these will fit the bill perfectly.......Now just need some nicer weather.
  • kaos1369
    kaos1369
    I took mine off the Breakout and fitted a full 2 into 1 system after working the engine up. If anyone is after a set hit me up, $180 you pay for shipping or pick up from Sydney. Great slip ons, awesome sound and make good power. In top condition, these are about $300-$400 new so this is a bargain. Will fit all Softails with new style bracket I believe.
  • Retroman
    Slash cut , slash down or tapered ?
    The Breakout Slip ons fit only Breakout/Heritage/ Softail Standard/Softail Custom.
    Sadly they don't fit a Fatboy.
    You'd have to do research to see if they will fit a Slim
