Compensator
  • bungalow1
    bungalow1
    I've been told the compensator should be replaced at about 30,000 ks. (2009 heritage softail)
    Is this bullshit?
  • markwoumla
    markwoumla
    Fucken Oath it should.. I am surprised you were told you would get to 30,000 ,,, And your cam tensioners will desintegrate at 35,000....While your in the cam chest , check the inner cam bearings,, there probably fucked already... The inner primary seal and bearing will shit themselves at 36,000 .... The clutches in Harley's are shithouse also, you will be slipping and sliding by at least 37,000..
    Not to mention the drive belt will need replacing at 38,000 , and fucking expensive .... And your front and rear rotors will definitely warp and need replacing by 39,000.. Others may chime in with other things that will need replacing at 30,000 km .... I take it, you have a service manual ?????
