Online: Stuart
Handle Bar Change
  • Iron
    Iron
    Okay I am thinking of changing the bars on my 2016 FXDB from the standard apes to a Fat drag bar or something similiar. Will i need to change any of the cables if i decide to go ahead with this. If i use the existing cables will they be to long and get in the way.
    I picked up a set of factory risers second hand from Gumtree which came off a wide glide and was hoping to use these. What bars are people using and where you getting them from.
    Any advice would be appreciated
  • Sparra
    Sparra
    If they are later model Wideglide risers you will need to source 1 1/4 bars as the wideglide bars don't step down in the centre...
  • FONTANA302
    FONTANA302
    I fitted Street Slammer bar (chrome) #55975-08A to my FXDB, needed 4" shorter clutch cable - standard wide glide #38787-06C. Throttle cables & front brake lines worked out OK.
