Online: vitalhemps
Oil draining for 1450
  • Kato
    Kato
    Hi
    Some advice if i could get it (thanks to those that commented on my leaking carbie) re oil changing on a 1450 HD motor
    The HD factory manual i have advises there is only 1 plug to undue when draining the engine oil and thats the one that is at the base of the oil tank
    I notice that theres another 1  located under the engine between the frame rails .
    Why wouldnt a HD factory manual point out the fact that there is another drainage point between the frame rails .
    i reckon youd get another litre of oil from from the engine by removing this drain plug - but the factory  manual makes NO reference to it (well as far as i can see it doesnt )
    any advice woudl be greatly appreciated
    have i missed something here ?
