Online: beaglebasher, Hilly
Reading maps thunder max
  • jim76
    jim76
    I have done about 500km since fitting the thunder max n i want to ck out how its going. i have read the pdf file n just want to comfrim reading whats in the bike. do i make a link between computer n bike then read modle maps this should show me all that has been going on in the last 500km or so. i only want to read the map dont want to make any changes at the moment bike seems to go ok. it idles high when starting hot n sometimes it backfires thourgth thottle body by what i can c these are only small changes to make to get it right i dont think there is any problem with these issues at the moment. thanks for any help
  • jim76
    jim76
    thanks skull for the info, just wanted to double ck so i didnt bugger any thing up. have you had any worries with your bike popping thourgh the thottle body when u give it a blip my bike does it sometimes i read in the pdf file that i can adjust this as well.
