Online: Wanderer57
vrod electrics
  • gcase2009
    gcase2009
    Hi guys, names case. Having an electrics issue that doesn't make sense. Had to take the air box off to replace broken breather so removed the maxi fuse as recommended only unplugged the wire going to top of air box at the same time pulled controls off bars and put on new grips including throttle body put everything back together re installed maxi fuse and no speedo, neither fuel reading or guage, odomometre not clicking over and blinker doesn't turn off after going round corner unless done manually. Have rechecked everything and all seems fine, have played with these parts of the bike numerous times before. Part of me keeps thinking back to mayebe the speedo sensor on the rear of the crankcase. Would all these things be running off the same wiring I know the speedo and blinkers are. Does anyone have any thoughts before I have to take to the shop.
    All those symptoms suggest it could be a problem with speed sensor or wiring to that sensor. Try looking around there and giving the sensor a clean? Any fault codes?
    How old is the bike?
  • gcase2009
    gcase2009
    Bike is an 09muscle and have checked wiring. Bike is going to get hooked up today and run a diagnostic check maybe that'll show something. The vrods have 2 work shop manuals i have the first and the second one is for electrics but I do think speed sensor just didn't know you could clean them thought was a throw away
    You're probably right re throwaway but can't hurt to try stuff
  • gcase2009
    gcase2009
    thanks for your input fatbat I think we're both on the same page with the sensor. will post the answer when I work it out. Happy riding
  • gcase2009
    gcase2009
    re used gasket between air box and injectors (looked ok) wrong error code said was air leak so brought new gasket and all problems with electrics came good. For whatever reason sucking air was screwing with sensors but $5 gasket running sweet again
    Great work glad it worked out and didn't cost too much time or money
