Online: Merv
Radio Reception
    My radio has lost reception , suspect a loose aerial conn . Though at the same time , stereo is repeating songs on ipod . About to remove batwing for a look . Any ideas , or similar probs out there ?
  • markwoumla
    markwoumla
    G'day Tim ,,, A couple of audio problems I see,,, You may have a hardware problem , (ie , loose or damaged cable), regarding the radio etc,, .. But for what its worth,, pull the maxi fuse , wait a coupe of minutes are re install .... Just like a computer , they reboot, and this can solve some of the crazy electronic problems .... You know the story,, do the easy things first .... Cheers ....
    Thanks Nomada , somehow head unit had gone to repeat . Changed to shuffle , all good now . Mark , tried easiest first , removed left pannier to check aerial connection . Lo and behold , nut had come loose , something for us to check occasionally .
  • Spook
    Spook
    The devil made me do it!
  • Odin
    Odin
    at least it didnt cost any coin to fix the issue. win win situation
  • markwoumla
    markwoumla
    Glad everything worked out ... With regard music on the 2015 street glide,, I had music set to shuffle , and you could use the left toggle switch, (for volume), to repeat or go forward to a new song ... All was going good, then all of a sudden the left toggle would not let me repeat that song or go forward to a new song anymore... Went into the functions,, and the shuffle was not ticked .. Ticked shuffle again, still not letting me do it... Ticked shuffle again, then turned the ignition off .. Turned everything back on ,, now all working as before .... Fucked if I know why it changed in the first place ,, the system certainly has a mind of it own .... Turning the ignition switch off, then back on, after changing certain setting seems to be the magic cure for these little problems .... Now back to working out the fucking NAV system a little better,, (not that I really need it that much) ......
  • Bilko
    Bilko
    Mine has a moment if i toggle the volume or track advance knob during the start procedure. Nothing works properly. Stop and restart all ok.
