Online: tussuck
2005 Ultra cutting out
  • Hywayman
    Hywayman
    my 2005 Ultra Classic keeps cutting out.....
    when it stops, the tacho goes to 3000-4000rpm & the fuel pump runs continously
    i've replaced the fuel pump relay, engine position sensor, re-wired the fuel pump fuse, replaced the fuel filter & regulator.
    checked all the battery connections & earths.
    at a bit of a loss at the moment & slowly working thru all the wiring looking for anythink loose or corroded
    any ideas or previous issues?
  • fat103
    fat103
    Maybey check the speed sensor in the tranny !! Could have metal filings on it that can cause similar sympthons.
  • Hywayman
    Hywayman
    i will check that out, thanks
    i've also found the tab broken on the harness connector into the back of the ignition switch.
    i'll order some new pins & a connector & fix that
