forward controls
  • Fat Tom
    Fat Tom
    Hey people, I am looking for a set of forward controls for my 07 fatty. I have been looking online the last couple of
    weeks on ebay and boy they can be pricey. Gumtree doesn't have any at the moment. Opinions wanted on products
    out there to help me make an informed choice, I know 07 was a year of many changes for the fatboy. Did they change footpegs?
    Are there any products I need to steer away from ? do you prefer footboards or pegs and why?
    hey someone might have a set they want to sell or even swap for my foot boards.
    I like footboards for comfort
  • Stevef
    Stevef
    I just fitted the Arlen Ness relocation plates on my Rocker. They move the pegs 3 inches forward and come with the extended brake line cor the rear brake. Piece of piss to fit, well made and only $300. Can't go wrong! Althouvh I'm sure someone will probably tell me otherwise. Ha!
  • Fat Tom
    Fat Tom
    I'm confused, asked 3 seperate HD shops about fitting factory forward controls from an 03 softail standard to my 07 fatty.
    First said absolutely not- differnent hole setup from flst-fxst models
    second said it should as the holes are the same
    third was unsure ,said it should fit but might need mods to fit , also that any  fatboy controls from 07-16 would fit.
    has anyone had any personal experience to help me as I would prefer to get a second hand set to save a bit of $.
