Online: tussuck
converting to led indicators
  • beehappier
    beehappier
    I have a 98 fatboy with a custom numberplate holder that has indicators included on both sides of the numberplate.
    It turns out that you can hardly see the indicators flashing when you are behind me so I figured it is time for an upgrade.
    If I upgrade to led indicators do I need to include resisters in the wiring, or upgrade the flasher cam or anything?
    Thanks.
  • beehappier
    beehappier
    Thanks mate. I figured it would be a simple solution.
  • oneup
    oneup
    just give then a bit of space  they an get warm
    Hey Hilly... guessing I need the same for my 2007 Dyna!!! Been looking at this, just buggered if I know where to fit it...
  • Tzukius
    Tzukius
    Mate, get onto the guys at HOG Lights (forum sponsor). They'll answer all of your questions and can provide all the hardware you will need.
  • beehappier
    beehappier
    Thanks for the tips everyone.
