Online: Rextheute2022
Alloy Art Frame Stabiliser
  • mickle
    mickle
    Who's that ugly cunt in ya starter motor?
  • markwoumla
    markwoumla
    Did you have what is described as the death wobble, (or similar), which is documented in some older framed touring bikes ?? Or was it a more intense wallowing through corners ??
    A few guys I know swear by a stabilizer like yours, or similar for better handling, tightening up, etc, even on the later and newer models ....
    One other thing,, I agree with Mickle ,, change the chrome cover on your starter motor,, cant have that ugly bastard stuck on there ,,, Cheers China .....
  • Deadwood
    Deadwood
    Mine wallows a bit in corners when pushing hard, especially on uneven surfaces
  • Geoff3DMN
    Geoff3DMN
    If the stabilizer restricts the movement of the engine does that reduce the effectiveness of the rubber engine mounts in stopping vibration from the motor at all?
  • coolvirgo54
    coolvirgo54
    I was really pissed with the handling on my 2013 ultra. Diving under braking, wobbles on uneven bitumen and bumpy bends. I changed the fork oil to a heavier viscosity, fitted an Alloy Art stabiliser and raised the rear shock pressure to 60psi - i usually ride with a pillion. The handling and braking have improved dramatically. Still have a little bit of tracking on ridgy bitumen but I will be ditching the rear Dunlop in favour of Michelin in a couple of weeks. Also fitting Monroe 785s.
  • coolvirgo54
    coolvirgo54
    I have now fitted the Monroe785 air shocks and a Michelin Commander II rear tyre. These mods plus fork oil and Alloy Art stabiliser seem to have pretty much sorted the ultra. Tyre pressure is really critical though - I am often at the weight limit of the bike with pillion and gear.
