Online: beaglebasher
Wider tyre for street rob
  • Streetrob2016
    Streetrob2016
    Hi
    Anybody upgraded rear tyre to wider size 250-300. How much roughly cost . I m in Croydon Victoria. Any mech recommended or should I go the Harley shop in Ringwood.
    Thanks
  • Big Steve
    Big Steve
    Heartland has a kit for 200 and 240mm
    Lots of work and big dollars.
  • Daggs
    Daggs
    200 fits easy with stock swingarm and still rides well, expect to pay around $3000 - $4000 give or take a bit to go to a 250-300
    Do you really want that on a Street bob? I wouldn't consider it an "upgrade"
    it will definitely wreck the great handling this model has or are you building a show bike that won't be ridden?
  • Streetrob2016
    Streetrob2016
    Thanks heapes
  • Streetrob2016
    Streetrob2016
    Will 200 fits in standard fitting? To
  • Daggs
    Daggs
    You need a wider rim, stock is 4.5" wide but a 200 needs 5.5" or 6"
    Also tidying up the wiring under the guard is needed so the tyre doesn't rub through it.
    New axle spacers may or may not be needed depending on the offset of the rim/hub used.
  • Streetrob2016
    Streetrob2016
    Thanks heapes.
  • capri_v6
    capri_v6
    Go and have a chat to Rick at all American in Ringwood
    He will be able to give you a rough idea of cost and his work is good
    Ben
  • Methuselah
    Methuselah
    If you really want to go wide get on to Walka, just search his name in the members list, he is a sponsor on here (VPN) and sells complete kits that look pretty darn good
  • Daggs
    Daggs
    how did you go? what did you decide?
    It's not a cheap bike to do but if you want to go up to a 250, I sell a 250 Swing arm kit for 2006 and Up Dyna , It is the Swing Arm, Struts Axle Primary Offset Kit and all the parts to modify the Gear Box $3200.00. You still have to get a Rear Fender $299.00 and Rear Wheel and Tyre .. Rick at all american or John at Doc Hogs in Bayswater would be my pick to fit it.around Ringwood
    Luke at Gworks in Geelong also makes a Kit for them he is also the right guy for fitting
  • Streetrob2016
    Streetrob2016
    Thanks I want more show bike. I will start saving .
