Online: Nino
Distance to empty
  • patgreyling@hotmail.com
    Hi Guys,  I recently changed the battery on my 2013 Road King.  Afterwards, I noticed that my "Distance to empty" electronic indicator is out of wack!  It seems to have stayed at the last readind (e 256 Km) when the battery was disconnected.  Even though I have now filled up the tank, it had not indicated the new distance to empty reading.  Help!   Any advice on how to reset that..... THANKS Pat
  • mickle
    mickle
    You have ridden it since filling? or did you fill it in the shed, if so it wont reset until you start riding.
    Hi Mate, thanks for the quick reply. Nope, I have ridden it for several hundred clicks and filled it twice...... just stays at the same distance to empty whether the tank is filled or much lower .... cheers Pat
