Online: beaglebasher, Hilly
Engine/primary/trains compatibliy
  • Justo
    Justo
    Gday all. I just wanted to confirm something... I have an evo engine, evo primary and aftermarket evo RSD gearbox. Now I can run a shovel, as long as I use the evo primary and gearbox.. Is that also the case with TCs? Now I know they need brackets and a spacer, but will a later model evo primary, fit the the Twin Cam engine so I can use the primary and gearbox? And does the Evo compensating sprocket shaft and nut  fit the twin cam also?
    Justo
    Look up Vulcan engineering in the USA thay make adaptor so you can mount a Tc In a evo frame/softail
    And run a evo primary I've never done it but may do it one day , could you image a 120r or bigger
    In a bike with a 160 tyre Some awesome power on skids there lol
